Ideal for curved cuts in wood (up to 10mm), corrugated boards (up to 3mm) and non-ferrous metals (up to 2.5mm). Equipped with a powerful 12-18 Volt 5-pole motor. Power consumption 100W, max. 6mm stroke. The number of strokes may be adjusted between 2,000 and 5,000 per minute. Stable housing of fibreglass reinforced polyamide. Includes two saw blades (coarse and fine).
We recommend MICROMOT mains adaptor from 2.0A for powering the jigsaw.
Note:
The speed control of our 12 volt devices only works when operated via nonstabilised power supply units (e.g. all MICROMOT mains adapters). Connection to stabilised power supply units is possible. However, the devices will then operate with maximum rotational speeds (also applies to operation with batteries).
