RotaCraft 400 Piece Rotary Tool Accessory Kit
106267
From £37.28 £31.07
  4. Empty Star
1 Review
In Stock - Ready to dispatch
  • 400 accessories for use with all rotary multi-tools
  • Be prepared for any multi-tool task
  • Storage case converts into bench stand
  • Easy to see, access and top-up
  • Bits for sanding, grinding, cleaning
  • Bits for drilling, cutting and polishing
  • All bits 2.4mm or 3.2mm shank
A great value accessory set for any rotary multi-tool, Proxxon, Dremel and most other brands. Because a rotary multi-tool is so versatile, you never know what use you will find for it next. At least with this kit you will always be prepared. Contained in the storage case are bits for sanding, grinding, cleaning, drilling, cutting and polishing.
The case contains 400 accessories in total for use with all multi-rotary tools. The shank sizes are 2.4 and 3.2mm. The case has a carry handle and slider catch to prevent it falling open when transported. It folds out, the lid forming a base, so it stands upright allowing easy access to the various bits.
3.00 1
