The Scorch Marker Pro is a unique way to create a pyrography effect on wood, card and even paper. Use the Scorch Marker to write or draw your design as you would with a normal pen. The ‘ink’ in this case is a chemical, which reacts with the wood when heated. The ink is non-toxic and safe. Once completed, go over the area with a hot air gun. When the temperature reaches 190°C, the design will magically begin to burn into the wood. Applying more heat further darkens the design. (It is possible to use an oven set at 190°C to achieve the desired effect.)
Using Scorch Marker allows you to exercise your creativity without the need of a high temperature pyrography iron. The improved forumla allows you to achieve faster and darker designs. Whilst the pigment adjustment allows you to achieve precise designs. Switch between two tips, one brush and one bullet tip, to achieve a variety of effects. Experienced pyrographers find Scorch Marker a useful addition. It has great potential when it comes to shading and enhancing a pyrographic illustration. What better way to sign and date a piece of furniture or woodturning?
Scorch Marker works on most types of wood; light coloured woods give better contrast. For best results, sand the surface down to 220 grit. Applying a light stain or oil prior to using the Scorch Marker will help achieve clean, crisp lines and prevent bleeding, or you can use a vinyl template. The 3mm chisel tip with a dispensing valve improves accuracy and application. The ink’s pinkish hue makes it easy to see. If you make a mistake just sand away the blemish and re-start. Detailed instructions on how to use the pen are on the back of the packaging. Made in the USA.
Scorch Marker: an odour free and non-toxic chemical wood-burning pen.
Unique method of wood burning; write or draw a design
