Shokunin Dozuki Universal Saw Blade
110853
From £17.58 £14.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • Replacement blade for Shokunin Dozuki Universal Saws
  • Impulse-hardened teeth for precision and durability
  • Rustproof nickel plating for corrosion resistance
  • 0.3mm thick blade with a 1.5mm tooth pitch
  • Stiff spine for stability and a 50mm depth of cut
  • Suitable for both rip and crosscuts
The Shokunin Dozuki Universal Saw Blade is a replacement blade for the Shokunin Dozuki Universal Saw. Its versatile and high-quality blade is designed for both rip and crosscuts. Its impulse-hardened teeth ensure precision and durability, while the rustproof nickel plating protects against corrosion. The blade's 0.3mm thickness and 1.5mm tooth pitch allow for smooth, effortless cuts, leaving a clean finish with minimal effort. The stiff spine provides stability, enabling a 50mm depth of cut, making it ideal for intricate woodworking tasks.
