Straight Tip Tweezers with Stand
505597
505597
- Reverse action tweezers open when squeezed
- Fibre scales protect fingers from heat when soldering
- Object held in one of four positions above the workbench
Show more
Show less
Reverse action tweezers are ideal for gripping all manner of small components when making jewellery. It becomes much more difficult to hold these small items if they need to be, for example, soldered or joined in some way as the tweezers are usually laid flat on the workbench. These innovative tweezers are not only reverse action, but have a square wire frame welded to one of the jaws, meaning that the item can be securely held above the surface ensuring easy access from either a soldering iron or micro torch.
EAN Barcode | 5052511097104 |
