From £799.98 £666.65
  • Celebrating 50-years of the best wetstone sharpening system
  • Incredible 50-year warranty, upon registration
  • Fitted with a DF-250 Fine Diamond Wheel
Customers Also Bought
Tormek of Sweden has produced this special anniversary edition of their renowned T-8 sharpening system to celebrate its 50th birthday. It represents 50 years of development and improvement culminating in this latest version of Tormek’s founder, Torgny Jansson’s original concept. Tormek Sharpening Systems are still the best and will remain so for many years to come.
The 50th anniversary model comes with a DF-250 fine diamond wheel and includes: a CW-220 Composite Honing Wheel, ACC-150 Anti-Corrosion Concentrate, a WM-200 Angle Master, the latest HB-10 Tormek Handbook, US-105 Universal Support, EM-15 Edge Marker, Embroidered Anniversary Machine Cover, special durable storage tray and an SQ-90 Tormek Square. So confident are Tormek in the quality of this machine it will be covered by a very generous 50-year warranty on registration.
This new Tormek T-8 sharpening system is the perfect answer to your sharpening requirements. Constant speed drive system and precise repeatability features, are the key to good sharpening. The diamond wheel is 250mm x 50mm water-cooled and the honing wheel 220mm x 31mm. Powered by a quiet 200W motor, Tormek’s unique and efficient drive system maintains constant speed, even under load. Tools can be sharpened with the wheel cutting towards or away from the edge. The T-8 features a strong, cast-alloy casing with impact-resistant ABS plastic sides which sit on top of a precision-cast zinc, powder coated, stand for maximum strength and stability. The mounting sleeves for the universal support are an integral part of the casting. The design eliminates the possibility of any misalignment between the universal support and the wheel. The universal support bar has a micro-adjuster, which makes setting up or replicating a sharpening angle easy and highly accurate. The Advanced Water Trough features a screw lift mechanism. You can fit it, fill it and then by simply turning the knob, raise the trough to bring the water into contact with the wheel. It makes removing the trough for emptying just as simple. The T-8 includes a magnetic scraper for efficient cleaning. The unit has an NVR safety switch with a strong waterproof cover. The Tormek wet-sharpening method leaves a polished, burr-free edge without overheating the tool. Wet sharpening significantly extends the life of your tools; it removes less material without affecting the temper of the steel.
For more tips on sharpening please see Tormeks YouTube channel.
50-year warranty, 5 years + 45 years when you register at tormek.com
  • Includes generous selection of accessories
  • Cast-alloy casing with impact-resistant ABS plastic sides for strength
  • Precision-cast zinc powder coated stand for ultimate stability
  • Micro adjustable for complete control of sharpening angle
  • Integral sleeves for support bar guarantees correct alignment
  • Screw lift rise and fall mechanism for water trough
  • Special Black Anniversary Machine Cover with embroidery
  • Sharpens all types of steel, including high speed steel (HSS)
Warranty Tormek 50 year Warranty, 45+5 (Registration Required)
    5.00 4
