Tormek T-8 Original Sharpening System & Hand Tool & Woodturner's Kits
- The original and still the best wetstone sharpening system
- Comprehensive kit of 6 jigs for sharpening common hand tools
- Comprehensive woodturner's sharpening jig set
- Revolutionary fully cast housing for strength and accuracy
- Micro adjustable for complete control of sharpening angle
- Integral sleeves for support bar guarantees correct alignment
- Screw lift rise and fall mechanism for water trough
- Sharpens all types of steel, including high speed steel (HSS)
- Includes upgraded SE-77 jig for precise 90° edges
- 8 year warranty (5+3)
T-8 Original Sharpening System with HTK-906 Hand Tool Kit and TNT-808 Woodturner's Accessory Kit – the ultimate sharpening solution for both hand tools and woodturning tools. This comprehensive system is designed to deliver precision and efficiency, ensuring your tools are always in top-notch condition. Whether you're a professional craftsman, a woodturner, or serious DIY enthusiast, the Tormek T-8 offers unparalleled performance with its advanced features and robust build. Paired with the HTK-906 Hand Tool Kit, you'll have everything you need to achieve razor-sharp edges on a variety of hand tools, from knives to chisels. Additionally, the TNT-808 Woodturner's Accessory Kit provides specialized jigs and accessories to perfectly sharpen your woodturning tools, enhancing your woodworking experience. Elevate your sharpening game with the Tormek T-8 and enjoy the satisfaction of perfectly honed tools every time.
Tormek T-8 Water Cooled Sharpening System
The Tormek T-8 sharpening system is the perfect answer to your sharpening requirements. For any professional or amateur needing a versatile, reliable and repeatable sharpening system, the T-8 should be on the top of your list. The T-8 has a 250mm x 50mm water-cooled grindstone and a 220mm x 31mm leather tyred honing wheel. Powered by a quiet 200W motor, Tormek’s unique and efficient drive system maintains constant speed, even under load. Tools can be sharpened with the Supergrind wheel cutting towards or away from the edge. The T-8 features a strong, cast-alloy casing. The mounting sleeves for the universal support are an integral part of the casting. The design eliminates the possibility of any misalignment between the universal support and the grinding wheel. The universal support bar has a micro-adjuster, which makes setting up or replicating a sharpening angle easy and highly accurate.
The Advanced Water Trough features a screw lift mechanism. You can fit it, fill it and then by simply turning the knob, raise the trough to bring the water into contact with the stone. It makes removing the trough for emptying just as simple. The T-8 includes a magnetic scraper for efficient cleaning. The unit has an NVR safety switch with a strong waterproof cover. The T-8 is suitable for use in education and other areas where an NVR switch is a necessity. The T-8 includes TT-50 Truing and Dressing Tool, SP-650 Stone Grader, WM-200 Angle Setting Guide, PA-70 Honing Paste and Dressing Oil for the honing wheel. In addition, there is a comprehensive handbook packed in a strong storage tray. The T-8 also includes the SE-77 upgraded jig for square edge tools.
8 year warranty (5+3) Tormek T-8 extended warranty of 5 years + 3 extra years upon registration.
Tormek HTK-906 Hand Tool Kit
Packed in a high quality storage case with an opaque lid and foam insert, the HTK-906 is a comprehensive kit of 6 jigs for sharpening common hand tools. The jigs enable you to sharpen a wide range of tools such as axes, scissors, long chef’s knives, short bladed knives, carving and butt chisels, pocket knives and garden shears.
The Tormek HTK-906 contains the following Tormek jigs: KJ-45 Short Knife Jig, KJ-140 Long Thin Knife Jig, SVX-150 Scissor Jig, SVS-38 Short Tool Jig, AX-40 Axe Jig and SVM-00 Small Knife Holder.
Tormek TNT-808 Woodturner's Accessory Kit
Packed in a second high quality storage case the TNT-708 is a comprehensive woodturner's sharpening jig set. The TNT-708 innovative Tormek tool set for woodturners contains everything you need to shape and sharpen all turning tools. The jigs give you complete control over the sharpening process. The jigs ensure you are able to reproduce and repeat your preferred bevel angles and tip profiles time after time.
The Tormek TNT-708 set includes the following Tormek jigs and accessories: SVD-186 Universal Gouge Jig, SVS-50 Multi-Jig, SVD-110 Torlock Tool Rest, TTS-100 Angle and Setting Gauge, LA-120 Honing Wheel, MH-380 Protective Cover and tuition manual.
This package deal consist of the following;
Fully cast housing for strength and accuracy
Kit contains:
KJ-45 Short knife jig
KJ-140 Long thin knife jig
SVX-150 Scissor jig
SVS-32 Short tool jig
AX-40 Axe Jig
HTK-00 Storage Tray for Hand Tool Kit
TC-800 Storage Case
Kit contains:
SVS-50 Multi jig
SVD-110 Torlock Toolrest
TTS-100 Turning Tool Setter
LA-120 Honing Wheel
Tuition manual
For more tips on sharpening please see Tormeks YouTube channel.
