Trend Cabinet Hardware Drilling Jig (CAB/JIG/A)
111837
Special Price £41.00 £34.17 was £50.98 £42.48 Save £9.98 £8.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • Ensures accurate fitting & spacing of cabinet handles
  • Self-centring scales with imperial and metric measurements
  • 4mm tool-steel drilling guide for fast, accurate hole centres
  • Reversible design
  • Protective rubber over-mould to prevent damage to doors
  • Made of durable polymer
This durable, polymer drilling jig is a time saver when it comes to drilling cabinet handles. Removing the need for traditional measuring and marking, this versatile jig allows you to achieve accurate and repetitive cabinetry handle installations, on a wide variety of door and drawer fronts. The quick 3-stage set up lets you configure the jig quickly using a standard screwdriver. Simply use the handles to set the drilling guide, set the edge guide to 1/2 drawer width and set the top guide to your chosen inset measurement.
It has self-centring scales with both imperial and metric measurements, eliminating the need for measurement calculations. The reversible design allows easy switching between left and right hung doors, whilst the protective rubber over-mould ensures door and drawers remain undamaged when positioning and using the jig. The 4mm tool-steel drilling guide allow you to make fast, accurate holes centres. It accommodates handle inserts from 30mm to 120mm from the top/edge of the door or drawer, with the sliding top guide. The sliding edge guide accommodates door and drawer sizes up to 600mm wide.
