Trend Letter Templates - A-Z
- Strong clear plastic letter and number templates
- For use with any plunge router
Trend Number Templates - 0-9Special Price £29.00 £24.17 was £35.48 £29.57 Save £6.48 £5.40
Trend Guide Bush & Cutter for Letter & Number TemplatesSpecial Price £21.98 £18.32 was £24.98 £20.82 Save £3.00 £2.50
Strong, clear plastic letter templates for use with any plunge router to write words for signs, including house names. The templates are used with a 13mm guide bush (not supplied) in the base of the router and standard 8mm cutter (not supplied) to produce 57mm high letters in upper case block characters in Trend Vogue type face. For certain routers the purchase of the universal sub base may be necessary.
Also available as numbers or as a complete set including cutter and template guide bush.
EAN Barcode | 5027654518786 |
