Trend Unibase for 1/2" Routers 180mm
- Nylon unibase with low friction surface
- 23 hole patterns to suit a wide range of routers
- Precision centring system to ensure accuracy
- QR quick pattern finder for location of the hole pattern
- Reinforced threaded brass inserts
- Compatible with Bosch, DeWALT, Makita, Festool and many more routers
HiKOKI M12VE Router In Case (1/2")Special Price £177.98 £148.32 was £197.98 £164.98 Save £20.00 £16.67
The Trend 180mm Unibase has 23 hole patterns and is suitable for most 1/2" plunge routers. It is made from reinforced nylon, ensuring a low-friction, precise routing surface for ease of use. It has a precision centring system, to ensure perfect concentricity between cutter and guide bush for precise accuracy with the routing jigs. A QR code features on the Unibase, to make locating the right hole pattern easy. Securely mount your guide bushes using the reinforced brass inserts. Includes a screw pack in a handy box, so you can find the correct screws with ease. Compatible with Bosch, DeWALT, Makita, Festool and many more routers including Trend T7, Festool OF1400, OF2000 and OF2200, Makita 2301, 2303 and 3612C, Mafell L055 and L065, Hikoki M12V2 and M12VE, Dewalt DWE625 and DW624E, Bosch GOF1600 and POF1200AE, Triton TRA001. It is also compatible with all Trend guide bushes. 180mm diameter x 9.5mm thickness.
EAN Barcode | 5027654086742 |
Model | unibase/180 |
