Trend Unibase for Router Trimmers 150mm
111840
From £34.98 £29.15
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Nylon unibase with low friction surface
  • 9 hole patterns to suit a wide range of routers
  • Precision centring system to ensure accuracy
  • QR quick pattern finder for location of the hole pattern
  • Reinforced threaded brass inserts
  • Compatible with Bosch, DeWALT, Makita, Festool and many more routers
The Trend 150mm Unibase for router trimmers has 9 hole patterns and is suitable for most 1/4" trim routers, including 18V cordless routers. It is made from reinforced nylon, ensuring a low-friction, precise routing surface for ease of use. It has a precision centring system, to ensure perfect concentricity between cutter and guide bush for precise accuracy with the routing jigs. A QR code features on the Unibase, to make locating the right hole pattern easy. Securely mount your guide bushes using the reinforced brass inserts. Includes M4 screws for router attachment. Compatible with Bosch, DeWALT, Makita, Festool and many more routers including Bosch GKF600, Makita DRT50 and RT0700, Triton TMNRTR and Ryobi R18TR. It is also compatible with all Trend guide bushes. 150mm diameter x 9.5mm thickness.
