TSO MFT Aligned Guide Rail Support Upgrade Kit
- Improves the accuracy of Festool’s MFT/3
- CNC machined aluminium replaces std plastic parts
- A significant improvement in accuracy
- Upgrades front and back guide rail supports
TSO Products DBF-45 BigFoot v2.0 Base Support Festool DOMINOFrom £109.98 £91.65
Upgrade your Festool MFT/3 multifunction table. This kit will make a significant improvement in the accuracy of the Festool MFT/3. It includes components to upgrade both the front and back guide rail supports.
Once fitted the kit minimises movement in the bracket assemblies attaching the guide rail support to the table's front and back extrusions, as well as restricting movement of the guide rail to just the vertical axis.
The TSO MFT/3 upgrade kit replaces Festool's stock plastic mounting brackets located on both the front and back guide rail supports, with precision CNC-machined brackets made from 6061-T6 aluminium.
The upgrade kit contains the following precision machined components; 2 x MFT Aligned Support Plates, 2 x MFT Aligned Feather Keys, 4 x Comfort Grip Dogs and 1 x Guide Rail Insert.
Restore confidence in the accuracy and repeatability of your Festool MFT/3.
Made in USA.
EAN Barcode | 850043733027 |
Model | 61-494 |
