UJK Compact Multifunction Workbench
109405
From £229.98 £191.65
5 Reviews
In Stock - Ready to dispatch
  • Ensures projects are square when cutting, clamping or assembling
  • Compact and portable; easily stored and transported
  • Perfect for work on site or in domestic situations
  • A mini workstation or small assembly bench
  • Valchromat top: generous 775mm x 430mm work area
  • Grid of 20mm dog holes at 96mm centres
  • T-Track for hold downs, doubles as a 'going bar' when sawing
  • Outer frame of high quality laminated birch plywood
  • Clamp cut-outs allow fixing to a bench top or table
  • Overall dimensions: L 785mm x W 465mm x H 160mm
A quality work surface, wherever you are
The UJK Compact Multifunction Workbench allows you to work on a quality surface, even when you don’t have access to your full size bench. Work on site, from the back of the van or in many other trade or domestic situations with ease.
Compact
This workbench is small enough to be stored under your bench when not in use, yet still provides a generous work surface area.
Portable
Weighing less than 12kgs, the workbench is ideal for those moving from site to site. Handles on either side mean you can transport it with ease. Overall dimensions: L 785mm x W 465mm x H 160mm.
Manufactured to last
With an 18mm thick Valchromat top and a laminated birch plywood frame, you don’t have to compromise on quality with this compact workbench.
Multiple uses
Use as a mini workstation or small assembly bench. Guarantee your projects are square with the grid of 20mm dog holes at 96mm centres - cutting, clamping and assembling are made easy.
Secure
Two clamp cut outs make securing the workbench to your surface quick and easy. 20mm dog holes are also featured on the front face and there is a T-track for vertical clamping.
Made in Britain
The UJK Compact Multifunction Workbench is made entirely in Britain, with many compatible accessories designed and produced here in Axminster, Devon but always throughout Britain as a whole.
Explore the UJK range...
This UJK Compact Multifunction Workbench gives you the advantages of the multifunction bench system in a compact, easily stored and transportable format. This compact version will be invaluable when working on site or in domestic situations without access to a full size bench. Use it as a mini workstation or small assembly bench.
The top is 18mm thick Valchromat, the same material as used for the full size UJK Multifunction benches. It offers a generous work area of 750mm x 430mm. A grid of 20mm dog holes at 96mm centres allow you to make use of bench dogs, UJK Cam Clamps and other UJK accessories. In addition, a length of T-Track provides potential for various UJK hold downs and doubles as a 'going bar' when sawing.
The outer frame is made from high quality laminated birch plywood, chosen for its strength and stability. It also features 20mm dog holes on the front face and a T-track for vertical clamping. Two clamp cut-outs allow temporary fixing to a bench top or table.
The overall dimensions are: L 785mm x W 465mm x H 160mm.
The worktop is certified by the Pan European Forest Council (PEFC).
British Made British Made
4.80 5
