UJK Two Wing Rebate Cutter & Collar
From £99.98 £83.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • British-made and designed to deliver precision, durability, longevity
  • Features ground breaking Internal Bearing Technology (IBT) offering superior running balance and protection from dust and debris
  • Features a unique two-wing design with replaceable blades
  • Produces straight and curved rebates with a clean, ‘glass-like’ finish
  • Features a blocking pin for depth disc changes, ensuring safe operation
  • Made from stainless steel, making it resistant to corrosion
  • Solid carbide, square, replaceable blades
  • Specifically designed for use with router tables
  • Available in 1/2" and 12 mm shanks
  • Supplied with UJK orange depth discs, available in metric (16 depth discs) and imperial (10 depth discs) sizes
The UJK Rebate Router Cutter is a new, innovative design of the much-loved rebate router cutter. British-made and designed to deliver precision, durability, longevity, and smooth, clean cuts, it is a worthy addition to any workshop.
The addition of the small size rebate cutter will be welcome in many workshops, where it’s suitable for both handheld and router table use. It features a square, replaceable blade on two flutes, as well as a blocking pin for depth disc changes, ensuring safe operation. It is available in 8 mm and 12 mm shanks.
UJK have created truly ground breaking technology with Internal bearing technology (IBT) featuring in both sizes of the rebate cutter. The IBT allows the twin bearings to sit low in the cutter, offering a superior running balance and protection from dust and debris, resulting in a smoother cutter and longer lifespan.
The British-made UJK Rebate Cutter is the only one of its kind made from stainless steel, making it resistant to corrosion. The solid carbide, square, replaceable cutters are held securely in place by Torx screws, ensuring they remain secure. The cutter sits in two points of positive register, providing maximum accuracy.
Supplied with UJK orange depth discs, available in metric and imperial.
Metric depth discs, rebate depth produced 1, 2, 3,4,5,6,7,8,9,10,11,12,13,14,15mm
Imperial depth discs, rebate depth produced 1/16", 1/82, 3/16", 1/4", 5/16", 3/8", 7/16", 1/2", 9/16"
British Made British Made
