UJK 10mm Phenolic Router Table Insert Plate
502747
From £82.78 £68.98
  5. Half Star
10 Reviews
In Stock - Ready to dispatch
  • UJK 10mm phenolic router table insert plate
  • Threaded lead-in pin
  • To fit 230 x 306mm aperture
  • Twist lock insert ring supplied with wrench
  • Range of central insert rings available
This phenolic insert plate measures 229 x 305mm and is designed to fit the UJK cast iron, phenolic or MDF router table tops. At 10mm thick, it offers a very substantial mounting for your router and comes supplied with a removable central insert with a 38mm central hole. Various inserts are available, including one that will accept a standard threaded guide bush for template routing. The insert will accommodate most portable routers and should be drilled to individual requirements.
4.50 10
