Supplied as a pair, these UJK Guide Dogs fit exactly into the 20mm holes of the UJK multifunction workbench. They are compatible with the Festool MFT/3 tabletop and similar grid tables with chamfered 20mm holes.
CNC machined from 303-grade stainless steel, the Guide Dog has a 12mm projection above the tabletop. The lower profile makes the Dogs ideal for situations where a taller dog would cause an obstruction. At 20mm diameter, it is fully compatible with many other Parf system and multifunction bench accessories.
The stop collar fits into a chamfer around the dog hole, providing a register that guarantees the dog sits perpendicular to the work surface and ensures a flush fit at the base. A UJK chamfer cutter is available to modify tables with plain holes, or you can use a router with a bevel cutter to create a slight chamfer.
When used in pairs the precision fit of the Dog is perfect for fixing other items or jigs with corresponding 20mm holes.
Supplied as a pair
Low profile, 12mm projection, 20mm diameter
Precise fit in 20mm holes of multifunction workbenches
Compatible with the Festool MFT/3 (with chamfered 20mm holes)
Fully compatible with other Parf and multifunction bench accessories
Perfect for fixing other items or jigs with corresponding 20mm holes
