UJK 3-in-1 Trammel Set
- 3-in-1 trammel set for marking out or measuring
- Can be used with dual pins, pin and pencil or pin and paper/card cutter blade
- Alloy extrusion bar gives rigidity and accuracy
- Clear scale marked in metric graduations
- Trammel heads made from coated machine steel with brass thumb screws
- Optional extra 64cm rail with joiner, giving 128cm length
Axminster Workshop Self Healing Cutting Mat - A2 (594 x 420mm)From £13.68 £11.40
Axminster Workshop Self Healing Cutting Mat - A3 (297 x 420mm)From £7.88 £6.57
Axminster Workshop Self Healing Cutting Mat - A4 (210 x 297mm)From £4.98 £4.15
Axminster Workshop Self Healing Cutting Mat - A1 (594 x 841mm)From £24.38 £20.32
This 3-in-1 trammel set can be used in three different ways. First, by using both pins to mark out or scribe an arc. Secondly, by removing one pin and fitting the included HB pencil. Thirdly, by replacing one pin with a paper and card cutter blade which is also included. The trammel bar is 64cm long and is made from a rigid alloy extrusion, creating an accurate marking out tool. The scale has clear metric graduations. The trammel heads are made from coated steel and have knurled brass thumb screws. A useful extra is the optional 64cm rail with joining bracket, creating a 128cm trammel set, very useful for taking off measurements or marking out large projects. This is another simple product that works extremely well.
EAN Barcode | 5052511100798 |
