UJK Dust Extraction Box
- Dust collection device
- Efficient extraction from above and below the table
- Access door with magnetic catch
- 63mm extraction hose included
- 100mm outlet
UJK Router LiftSpecial Price £409.98 £341.65 was £449.98 £374.98 Save £40.00 £33.33
UJK Professional Coping SledSpecial Price £149.98 £124.98 was £179.98 £149.98 Save £30.00 £25.00
Dust extraction from a router table can be difficult and for it to work effectively it needs to extract from both above and below the table. Designed to fit the UJK Pro and Compact router tables this device fits below the table top enclosing the router. It could also be fitted to other custom-made tables of your own design. The 100mm diameter outlet on the back also incorporates a 62mm inlet and hose which enables extraction from both above and below the table simultaneously. An access door is provided on the front with a magnetic closure enabling access to your router for adjustments if required. Measures 330 x 260 x 350mm high with an access aperture of 225 x 170mm.
Please Note: Not compatible with 720970 router motor.
EAN Barcode | 5052511054718 |
