Special Price £198.00 £165.00
was £376.38 £313.65 Save £178.38 £148.65
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
  • A unique and ingenious router table
  • Perfect for making small, precision components
  • Suitable for Bosch GKF 600 palm router
Customers Also Bought
The UJK OTORO Compact Palm Router Table is a unique and ingenious piece of equipment. It is perfect for model makers, dolls house builders and any craftsperson wishing to make smaller sized, precision components.
It is designed to be used with the Bosch GKF 600 palm router. Install the router, connect the dust extractor port and you are ready for business. You can clamp the table to a bench top or work table up to 60mm thick, allowing you to use it wherever is convenient. The table has both coarse and fine feed adjustments for exact height modification of the cutter.
Three modes of operation are possible with this router table: preparing an edge, planing the board to width and moulding.
Edge preparation: the Rear Planing Fence consists of 2 sections, a fixed outfeed and an adjustable infeed. The adjustment uses a ‘folding wedge’ arrangement, where one slides against the other controlling the depth of cut. Very fine control and accuracy come from the 10:1 scale. Moving and locking the leading wedge 1mm produces a cutting depth of only 0.1mm. A featherboard is included to keep the timber securely against the fence.
Width planing: the Rear Planing Fence is replaced by the Rear Featherboard Fence. The Front Fence, complete with a similar folding wedge adjustment, is used to set the planing width of the board. Although looking somewhat unconventional, this method will produce very precise thicknesses. The maximum board width that will fit between the featherboards is 130mm. By using double-sided tape and sticking a workpiece onto a carrier, you can prepare very thin material.
Moulding: the Compact Router Table performs in much the same way as a conventional router table. In this case, the result is a small and exact profile. The table comes with a 12mm and 24mm insert (the 24mm is stored under the table) and with the insert removed a 40mm aperture is available to accommodate different sized cutters. When not in use the table can be stored under a bench or in a small cupboard.
  • Clamps to a table or bench top up to 60mm thick
  • Built in router lift with fine feed adjustment
  • Choice of 3 modes of operation detailed below
  • Edge preparation: fine control, 0.1mm depth of cut possible
  • Width planing: exact thicknessing of small section timber
  • Moulding: produces small precise profiles
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    4.50 21
