This unique spare part replaces the locking shaft of a UJK Super Dog, converting it into the taller Long Super dog. The conversion increases the projection of the dog above your multifunction table's surface to 120mm. With the extra height, you can make full use your saw’s maximum full depth of cut.
The ability to place your guide rail on top of thicker timber offers you the potential of making much deeper cuts and undertaking joinery and carpentry tasks. A Long Super Dog lets you cut or trench thicker pieces with the guaranteed accuracy you get from the multifunction workbench system. A pair of Long Super Dogs and a guide rail opens up a wider range of routing possibilities.
All Super Dog parts are manufactured from 303 stainless steel, CNC machined to exceptionally fine tolerances. Both the Super Dogs and Long Super Dogs only require a simple twist of the top to lock them firmly in position, perpendicular and rock solid.
The Super Dogs and Long Super Dogs are compatible with the Festool MFT/3 and self-built grid tables made using UJK Parf Guide System.
We recommend using the Dog Rail Clip (102973) with the Long Super Dogs.
