UJK Professional Laminated Router Table Top
- Low friction phenolic laminate surface
- Aluminium extrusion track for mitre fences and accessories
- Thick birch ply core; will not warp over working life
- Accepts any UJK table insert
- Dust collection box available
- Designed to fit onto UJK Professional leg stand and fence
- Table top thickness: 27mm
UJK 10mm Aluminium Router Table Insert c/w Universal BaseFrom £177.38 £147.82
The UJK Professional Laminated Router Table Top is high grade birch ply with a hard wearing, low friction, phenolic laminated surface. The ply core ensures the top will remain flat throughout its working life, while the laminated top ensures workpieces glide smoothly. An extruded aluminium track inset into the tabletop includes a standard 19mm track for the use of a mitre fence and a T-track slot for other jigs and accessories. The 230 x 306mm central aperture will accept any of the UJK router table inserts as well as the UJK router elevator. The top measures 800 x 600mm and is pre-drilled to fit the UJK Professional router table leg stand, fence assembly or optional dust collection box. Table top thickness: 27mm.
Rating | Trade/Professional |
Table Size | 800 mm x 600 mm |
