Veritas Crosscut Carcass Saw 14tpi - 275mm
- 0.5mm thick high-carbon steel 14tpi blade; cuts easily and stays true
- Injection moulded back creates a solid one-piece blade/spine/mount assembly
- Brass nut secures comfortable hardwood handle
- Overall length 415mm(16.1/4")
The saw has a 275mm (11") long by 0.5mm thick high-carbon steel blade filed crosscut at 14tpi. The teeth have a rake angle of 15°, an included angle of 60° with alternate 15° bevels to efficiently sever wood fibres rather than tear. The depth of cut is 60mm. The back of this saw is injection moulded under high pressure onto the blade and stainless-steel handle-mounting bolt. This forms a solid one-piece blade/spine/mount assembly. The material used for the back incorporates stainless-steel powder for weight, glass fibre for stiffness, and a polymer resin binder. A brass nut fastener secures the comfortably shaped hardwood handle. The saw has great balance it cuts easily, stays true and the grip makes for a comfortable and secure grip. Overall length 415mm (16.1/4")
Blade Thickness | 0.50 mm |
EAN Barcode | 722356011058 |
Kerf | 0.70 mm |
Length of Blade | 275 mm |
Overall Length | 415 mm |
Tooth Pitch \ tpi | 1.81 mm \ 14 tpi |
