Veritas Medium Router Plane
From £142.98 £119.15
  • Ideal for cutting dadoes, grooves and inlay or intarsia work
  • Supplied with either 1/4" or 1/2" blades
  • Accepts blades from larger Veritas router plane
Slightly larger than the Veritas small router plane, this tool has the advantage of using the same blades as the full-size router plane. This means any of the blades available for this will fit. The plane can be used as a closed mouth router or the blade can also be used in an outboard configuration, with the blade extending past the body for bullnose applications. The blade-clamping knob uses a wave washer to hold the blade as it is loosened for easy, controlled depth adjustment. An included stainless steel depth-stop collar locks onto the blade shaft to limit cutting depth to a preset maximum. The plane can make cuts up to 1" deep with the depth stop installed or up to 1.3/4" deep without it. The ductile cast iron body has been accurately machined and ground flat. The plane is 3.1/2" wide by 3" deep and weighs about 13oz. A versatile plane, particularly on narrow material or in confined areas. Available with either a 1/4" or 1/2" blade.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.90 7
