Veritas Optional Set of 6 Shims for Domino Table
- Set of 6 comprises 2 each; 2mm, 4mm and 8mm
- Creates vertical offset on Veritas Domino Joinery Table
- Allows adjustments of 1mm increments
- Made in Canada
UJK Drill Guide with 10mm ChuckSpecial Price £149.98 £124.98 was £179.98 £149.98 Save £30.00 £25.00
These shims are used on the Veritas Domino Joinery Table. This set of six comprises two each; 2mm, 4mm and 8mm. The shims are used to raise the Festool Domino DF 500 to create the vertical offset for your project requirements. The shims fit either into the slots in the milled cavity for the Domino base plate, or they can be placed on each side of the cavity. This allows adjustments to be made of 1mm increments, depending on the desired vertical offset of the mortice.
Made in Canada.
EAN Barcode | 722356026854 |
