The Side Rebate Plane is used for cleaning up or trimming sidewalls of rebates, dados or grooves. It has a practical dual-blade configuration, coupled with an ingenious pivoting sculpted to fit comfortably handle that permits right or left-hand use to accommodate grain direction. The thin sole functions much like a skate, allowing use in slots as narrow as 4.8mm(3/16") and to a depth of 12.7mm(1/2"). The toe is removable for use in stopped dados and has a fixing screw that is trapped to prevent loss. The depth stop helps orient and stabilise the plane during use and is both height adjustable and reversible. The accurately machined, 115mm(4-1/2") long ductile cast iron plane body and the two O1 tool steel blades (HRC 58-60) are lapped. The lapped blades have a flatness tolerance of ±0.005mm or better over the working surface, and with an average roughness surface finish of 0.000127mm(5 microinches) or better. Weight 450g. Made in Canada.
For cleaning up, fine fitting or trimming of rebates and grooves
Dual-blade configuration, pivoting handle for right or left-hand use
Use in slots as narrow as 4.8mm
Toe is removable for use in a stopped dado
115mm long, weight 450g
Ductile cast iron body with O1 tool steel blades (HRC 58-60)
