Veritas Steel Honing Plate
502403
From £38.58 £32.15
In Stock
  • Precision ground to a flatness tolerance of 0.127mm (0.005")
  • An excellent substrate for diamond paste (available separately)
  • Stays flat over a lifetime of ordinary use, size 204 x 76 x 9.5mm
Precision ground to a flatness.
It has a tolerance of 0.127mm (0.005") over the entire surface, this honing plate is an excellent substrate for diamond paste. The dimensionally stable low carbon steel will retain its flatness over a lifetime of ordinary use. The machining process creates a slight texture. This helps to capture diamond grit without compromising overall flatness. In use, the diamond particles readily embed into the softer steel to form a durable, fast-cutting abrasive surface. A dedicated plate for each grit size, should you choose to use more than one, cuts the risk of cross-contamination. Each measures 204 x 76 x 9.5mm and weighs 1.1kg.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
3.30 3
