Wood Repair PLUS+ Kit - 230V
- Repair cracks, knots, splits, holes and other defects
- Fast and easy to use, suitable for outdoors and indoors
- Use Knot Filler on edges and corners
- Unique wood repair product with many advantages
- Flexibility, strength and durability in one product
The Wood Repair PLUS+ Kit is designed for busy trade workshops, floor installers, carpenters, and one person workshops. Anyone needing to repair or fill knots, splits, cracks, holes and other defects in timber. Whether it’s repair or renovation, this unique product saves money, time and wastage. This kit contains all components to make near invisible repairs.
Thermelt Knot Filler is heated in an applicator similar to a hot melt glue gun. Squeeze the applicator’s trigger, apply molten Knot Filler into the defect. Place the cooling block on top, wait for a short time, then remove the block and trim off excess filler with the Flush Cutting Chisel. It takes about as long as it took to read this. It is easy and quick to use, durable and strong at the same time. Knot Filler is both water-repellent and flexible, which also makes it perfect for outdoor use. It is a non-toxic product, safe for the user and the environment.
The Wood Repair PLUS+ Kit includes:
Content:
1 x Wood Repair BCD-180 Thermelt® Application Gun c/w Changeable Nozzle (Pre-Adjusted Temperature - 170º)
16 x Knot Filler Sticks 150mm x 12mm (2 each: Mahogany, Pine, Oak, Knot Filler, Ash, Beech, Walnut and Black).
2 x 50mm x 50mm Aluminium Cooling Bricks (Heatsinks)
1 x 50mm Flush Cutting Chisel
1 x Knot Filler Saver
1 x Robust Storage Case
Thermelt Knot Filler is made from polyamide. It has excellent adhesion and due to a certain amount of flexibility it is unaffected by timber’s seasonal movement. It is suitable for both indoor and outdoor applications and available in a wide range of wood shades..
