Out of Stock
Veritas
Veritas 3 Piece Metric Tapered Snug Plug Cutter Set
SKU: 510269
£40.78
£33.98 Excl. VAT
  • Snug plug cutters cut a slightly tapered plug (3taper)
  • Metric set of 3 includes; 6, 8 and 10mm
  • 4 cutting flutes for clean sided plugs
Sometimes when plugging holes, no matter how carefully drilled, the holes finish up slightly oversize for the plug, especially in soft woods. These cabinet maker's snug plug cutters overcome this by cutting a slightly tapered plug. The first 3mm of the plug is the diameter stated whilst the remaining length is then flared out at an angle of 3. Just tap the plug into place until you meet resistance then cut off the excess. Also, unlike regular plug cutters which have two cutting flutes, these plug cutters have four, giving a much cleaner cut and a smooth-sided plug which fits perfectly every time and is practically invisible. For best results use in a drill press or power drill stand.
Web Attribute Set Plug Cutters & Plugs
