Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Veritas Bench Anchor
Code: 210539
  • Barrel-shaped insert nut that secures in any 19mm(3/4") diameter hole
  • Self-anchoring, removable and reuseable
  • Use horizontally or vertically
  • Accepts common 1/2" UNC threaded bolts
  • Pull-out strength of at least 90kg in hardwood
  • Useful for fixing jigs, guides, etc.
  • All-steel construction
  • Made in Canada
  • Show More
£11.26 (£9.38 Ex. VAT)
In stock - get it Tuesday 2nd Jun, order within and choose Premium delivery
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (5-7 day) - £2.95
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
  • Veritas Bench Anchor
  • Veritas Wonder Pups
  • Veritas Dovetail Saw for Saw Guides
Total: £60.92
Description
In Detail
It is easiest to think of this as a barrel-shaped insert nut that secures in any 19mm(3/4") diameter hole, except this one self-anchors and is removable. Usable horizontally, vertically or at any angle in between, it accepts common 1/2" UNC threaded bolts, and will wedge in through-holes in material as thin as 16mm(5/8") or in blind holes 32mm deep. With pull-out strength of at least 90kg in hardwood, the anchor has a wedging mechanism controlled by an integral hex-head screw drive and an external rubber O-ring that uses friction to hold it in place during installation. Though any 1/2" UNC threaded rod or bolt may be used with our bench anchor, we offer a small selection of flat-head and round-head fasteners here for convenience. Made in Canada.
Information Downloads
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
