Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
The Veritas Bevel-Up Jointer is the largest member of the bevel-up bench plane family. At 560 x 73mm and weighing 3.4kg, it is the answer for jointing edges and flattening large panels. The bevel-up blade configuration results in a plane that is versatile and straightforward to use. The 12° bed angle, coupled with the 25° blade bevel, creates an effective cutting angle of 37°. Simply increasing the blade bevel results in higher cutting angles for improved performance in more difficult grained woods. An adjustable throat plate allows a wide range of mouth adjustment. A unique stop-screw retains mouth settings while preventing blade damage when removing and replacing blades. The lapped blades have a flatness tolerance of ±0.005mm or better over the working surface, and with an average roughness surface finish of 0.000127mm or better. Supplied with a 57mm wide lapped blade, 4.75mm thick in the highly acclaimed PM-V11 alloy steel. Other blades are available as optional extras.
