Veritas Camber Roller
202489
From £29.38 £24.48
5 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 20th May
  • Specifically designed for the Veritas Mk.II Honing Guide
  • Solid brass barrel-shaped roller; Simply replaces standard roller assembly
  • Allows slight curvature with an accurate and consistent bevel angle
  1. Veritas Camber Roller
Total:
£118.12 £98.43
This is an attachment specifically designed for use with the Veritas Mk.II Honing Guide. When planing on large, flat surfaces, it is often desirable to hone a slight curve, or camber, into the edge of the blade. The Veritas Camber Roller Assembly has a barrel-shaped roller that allows limited rocking, whilst still maintaining an accurate and consistent bevel angle. Simply replace the standard roller assembly with the camber assembly and sharpen. The blade is still set using the registration jig, and the camber roller includes the standard eccentric system allowing micro-bevels to be honed.
5.00 5
