From £24.48 £20.40
  • Excellent for cutting projecting dowels or plugs
  • Double edged 22tpi with teeth set one way
  • Single edged 26tpi with no set
Customers Also Bought
Traditionally used for the rapid trimming of plugs and dowels flush with a surface, these flush cutting saws can be used where you want to cut off a projection without damaging the surrounding or adjoining face. The Japanese tooth pattern blade cuts aggressively (on the pull stroke), but does not mark the surface that it is cutting next to. The thin blade is flexible and can be pressed flush to any surface, yet is rigid enough for good control. The saw is available with teeth cut on only one edge with no set or in a double edged style that cuts from either side with the teeth set in one direction. Each is about 290mm long with 120mm of blade. These work like a charm.
  • Japanese style tooth pattern
  • Flexible blades cut on the pull stroke
  • Overall length 290mm(11.1/2") with 120mm(4.3/4") blade
  • Made in Canada
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    4.80 21
