This vice is easy to install in any bench with a top thickness at least 31.7mm (instructions, template and mounting hardware provided). The vice fits flush to your bench top and functions in a similar manner to a wagon vice. If your bench doesn’t have a tail vice then the Veritas Inset Vice coupled with a row of dog holes and a bench dog is exactly what you need. A knurled stainless-steel toggle handle turns a 13mm diameter Acme-threaded steel rod giving a travel of up to 100mm to a moving plate. A 13mm tall dog locates into this plate in one of two positions. Two positions allowing you to have dog holes on your bench top as far apart as 195mm. When the vice is not in use, removing the jaw leaves you with an unobstructed work surface. Constructed of machined steel castings and anodised aluminium extrusions. Made in Canada
Veritas
Veritas Inset Vice
| Web Attribute Set | Miscellaneous Vices |
| EAN Barcode | 722356011232 |
