Serving the dual purposes of topping off the teeth of a hand saw prior to re-sharpening, and providing an accurate guide for filing the edges of cabinet scrapers. A file with a maximum thickness of 4.7mm, typically a 150mm second cut hand file, is clamped into the guide and run across the saw teeth or the scraper to produce an even and square result. The 45
Veritas
Veritas Jointer & Edger
| Web Attribute Set | Saw Sharpening & Guides |
