Veritas Magnetic Corner Chisel - 9.5mm
475273
From £47.98 £39.98
  5. Half Star
3 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Thursday 10th Jul
  • Designed specifically for squaring off the corners of routed hinge gains
  • Precision-ground with a 35° bevel on each face
  • Two imbedded rare-earth magnets hold the chisel squarely in place
  1. Veritas Magnetic Corner Chisel - 9.5mm
Total:
£200.65 £167.21
This chisel is designed specifically for squaring off the corners of routed hinge gains. The 9.5mm(3/8") square blade is precision ground with a 35° bevel on each face, made of long wearing A2 tool steel, and hardened to Rc60. Though it can be used on its own, greater accuracy is ensured by use of the 50mm tall anodised aluminium guide block. Two embedded rare earth magnets hold the chisel squarely in place, while the outside faces of the block register against the routed pocket. A tap on the chisel cuts the corner square and flush with the routed edges. You will come to appreciate the fine edge and long wearing properties of the chisel when you finally have to re-sharpen it, as sharpening corner chisels is never an easy task!
4.30 3
