Veritas Medium Shoulder Plane
- Multi-purpose, highly accurate plane
- Exceptional clean cuts on end grain (e.g. trimming tenon shoulders)
- Unique lever cap with a pivoting knob
- Supplied with a 25° lapped blade in PM-V11 alloy steel
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23 -
Axcaliber Ground Tooth Bandsaw BladesFrom £11.98 £9.98 was £11.98 £9.98 Save £0.00 £0.00 -
Axminster Stainless Steel Metric Rule - 300mmSpecial Price £2.95 £2.46 was £3.28 £2.73 Save £0.33 £0.27 -
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75 -
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)Special Price £16.45 £13.71 was £18.28 £15.23 Save £1.83 £1.52
The Veritas Medium Shoulder Plane cuts exceptionally cleanly on end grain (for example, trimming tenon shoulders). It makes quick work of paring cross grain as is often required when fitting tenon cheeks. It is equally useful for rebate work, planing with the grain. This plane measures 178mm long by 17.5mm wide and weighs 906g. If you have ever held a traditional shoulder plane, you will appreciate how this plane comes readily to hand. The unique lever cap with a pivoting knob adjusts to fit your hand, allowing a secure grip without the need of vice-like pressure.
| EAN Barcode | 5052511077120 |
| Nett Weight | 910 g (2lb) |
| Plane Blade Width | 17.5 mm (11/16") |
| Plane Sole Length | 178 mm |
- Standard Delivery* - Free
