For our latest updates about delivery and stores, click here
Veritas Metal Bender & Axminster Power Nibbler - PACKAGE DEAL
717696
£46.94 £39.12
Out of stock
  • Veritas Metal Bender
  • Allows you to form a metal part with control
  • Made of high-strength malleable cast iron
Customers Also Bought
Package deal comprises of the Veritas Metal Bender and the Axminster Power Nibbler.
There are times when you need to bend a metal part, and simply using a vice and some brute force just won't do the job. This metal bender allows anyone to form a metal part with control. The product has two parts: the male die and the V-block. Both are made of high strength malleable cast iron, capable of bending up to 3.2mm(1/8") mild steel. Each piece (about 75mm(3") long by 28mm(1.1/8") wide) clamps itself against a vice jaw using embedded rare earth magnets. The main purpose of the metal bender is to make bends up to 90° for such things as angle brackets and sheet metal parts. Using the V-block on its own, you can securely hold rounds such as rods, tubes and dowels. Combining the V-block with a C-clamp makes easy work of repairing a chair leg. The male die on its own can hold complex curved or concave parts between the jaws. A versatile and inexpensive tool for any workshop.
This power nibbler fits into the chuck of a mains power drill and is capable of cutting sheet steel up to 2mm. For best results the drill speed should be in the range of 1,500 to 3,000 rpm. It works on the same punch and die system as a true powered nibbler, effectively removing tiny crescent-shaped pieces of waste in a continuous chain.If you want to cut aluminium, please use a cutting lubricant or soap. Some alloys are sticky and will clog the nibbler with waste. Cleverly, this nibbler is double headed, with the handle screwing over the head which is not in use, so when one die becomes worn, the handle can be swapped over and the other head brought into use. A spare punch and die are included within the steel storage box.
  • Capable of bending up to 3.2mm(1/8") mild steel
  • Clamps against a vice jaw using embedded rare earth magnets
  • Make bends up to 90° for angle brackets and sheetmetal parts
  • A versatile and inexpensive tool for any workshop
  • Axminster Power Nibbler
  • Fits into chuck of mains power drill
  • Capable of cutting sheet steel up to 2.0mm
  • Punch and die system
  • Spare punch and die included with steel storage box
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
