Veritas Mk.II Honing System and Camber Roller - PACKAGE DEAL
717456
From £84.98 £70.82
In Stock
- get it Thursday 23rd Mar, order within and choose Premium delivery. Delivery info
  • Veritas Mk.II Honing System
  • Increased range, capacity and accuracy
  • Integral blade registration squares the blade and sets the bevel angle in one easy step
Customers Also Bought
Total:
£145.22 £121.02
Package deal comprises the Veritas Mk.II Honing System and the Veritas Camber Roller
The main feature of the Veritas Mk.II is its blade registration system squaring and setting the blade in one easy step. The Mk.II Guide has three bevel angle range configurations: a high angle (25° to 54° in seven increments), standard (15° to 40° in six increments), and a third for back bevels. The registration jig slides onto the guide body, centering and squaring the blade using an integral fence. The clamping mechanism registers on the face of the blade and is designed to accept flat and tapered blades, as well as blades with irregular geometry. The Mk.II features a three-position eccentric roller allowing a micro-bevel to be honed quickly and accurately after only a simple turn of a knob. The 50mm wide roller is stable for even the narrowest of blades. The guide can easily accommodate chisels or blades from 12 to 72mm wide and up to 13mm thick including spokeshave blades. Sharpening stone not included
This is an attachment specifically designed for use with the Veritas Mk.II Honing Guide. When planing on large, flat surfaces, it is often desirable to hone a slight curve, or camber, into the edge of the blade. The Veritas Camber Roller Assembly has a barrel-shaped roller that allows limited rocking, whilst still maintaining an accurate and consistent bevel angle. Simply replace the standard roller assembly with the camber assembly and sharpen. The blade is still set using the registration jig, and the camber roller includes the standard eccentric system allowing micro-bevels to be honed.
  • Three bevel-angle range configurations
  • Designed to accept flat and tapered blades, as well as blades with irregular geometry
  • Three-position eccentric roller allows a micro-bevel to be honed quickly and accurately
  • 50mm wide roller is stable for even the narrowest of blades
  • Accommodates chisels as narrow as 12mm and blades as wide as 72mm and up to 13mm thick
  • Works with short blades such as spokeshave blades
  • Manufactured from die-cast zinc alloy, with precision-machined brass and steel parts
  • Veritas Camber Roller
  • Specifically designed for the Veritas Mk.II Honing Guide
  • Solid brass barrel-shaped roller
  • Allows slight curvature with an accurate and consistent bevel angle
  • Simply replaces the standard roller assembly
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    3.70 19
