Veritas Short-Blade Honing Guide
- Problem solved, sharpen small blades
- Foolproof guide for spokeshave and short blades
- Blades up to 66mm wide and 6.35mm thick
Axminster Professional Forged Flat Bar Clamp 200 x 80mmSpecial Price ÂŁ11.68 ÂŁ9.73 was ÂŁ15.58 ÂŁ12.98 Save ÂŁ3.90 ÂŁ3.25
Axminster Professional Combination Square Metric 300mmSpecial Price ÂŁ14.98 ÂŁ12.48 was ÂŁ18.88 ÂŁ15.73 Save ÂŁ3.90 ÂŁ3.25
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price ÂŁ66.40 ÂŁ55.33 was ÂŁ89.98 ÂŁ74.98 Save ÂŁ23.58 ÂŁ19.65
WoodSpur Torx Head Wood Screw Assortment (1,500 Pieces)Special Price ÂŁ24.98 ÂŁ20.82 was ÂŁ29.98 ÂŁ24.98 Save ÂŁ5.00 ÂŁ4.17
Axminster Professional Stainless Steel Metric Rule - 300mmSpecial Price ÂŁ2.68 ÂŁ2.23 was ÂŁ3.58 ÂŁ2.98 Save ÂŁ0.90 ÂŁ0.75
Thanks to Veritas’ designers and engineers the problem we face when sharpening spokeshave, small or short blades has been solved. Spokeshave, small block plane and palm plane blades are too small for most guides. This Veritas honing guide does the trick and is simple and foolproof to set up and use. Blades up to 66mm wide are easily aligned with the guide’s registration jig. It will take blades up to 6.35mm thick and sharpen 25° or 30° bevels. The adjustable fingers on the guide hold blades of all shapes securely at the correct angle. A shim included with the guide allows you to add a 2° micro-bevel.
Made in Canada.
EAN Barcode | 722356026434 |
Model | 05M09.30 |
- Standard Delivery* - Free
