From £212.58 £177.15
  • Versatile; excels at trimming rebates and planing end grain
  • Blade flush with sides, corners are clean and accurate
  • Skewed blade makes cutting easier; helps pull the fence into the work
Customers Also Bought
This versatile plane excels at trimming rebates and planing end grain. Of course, you can also use it as a normal block plane. Its Norris-style adjuster guarantees precise blade setting. Machined and surface ground, the 162 x 44mm body is ductile cast iron. It has a 12° bed angle and a movable toe fully enclosed by the body casting. A hardwood knob locks the toe to control the mouth opening. A setscrew in the throat acts as a stop allowing exact repositioning of the toe. The blade sits flush with the plane’s side, so corners are clean and accurate. Setscrews on either side prevent the blade from shifting in use. An adjustable spur, ahead of the blade reduces tear out on cross grain. The blade’s 15° skew, makes cutting easier and helps pull the fence into the work.
A brass knob and collet lock the 88mm long, 8mm thick hardwood fence. Tapped holes in the fence casting allow the fitting of a customised fence. The plane is available in left and right hand versions. It comes with an A2 lapped blade; 3.2mm thick, 38mm wide with a 25° bevel. The lapped blades have a flatness tolerance of ±0.005mm or better over the working surface, and with an average roughness surface finish of 0.000127mm(5 microinches) or better.
  • Norris-style adjuster guarantees precise blade setting
  • Movable toe (fully enclosed by the body casting) adjustable mouth
  • Skewed blade makes cutting easier and helps pull the fence into the work
  • Available in left- and right-hand versions
  • Supplied with an A2 lapped blade, 3.2mm thick
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
