Veritas Steel Honing Plate
502403
From £39.98 £33.32
  4. Half Star
3 Reviews
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Friday 20th Jun
  • Precision ground to a flatness tolerance of 0.127mm (0.005")
  • An excellent substrate for diamond paste (available separately)
  • Stays flat over a lifetime of ordinary use, size 204 x 76 x 9.5mm
  1. Veritas Steel Honing Plate
Total:
£81.62 £68.02
Precision ground to a flatness.
It has a tolerance of 0.127mm (0.005") over the entire surface, this honing plate is an excellent substrate for diamond paste. The dimensionally stable low carbon steel will retain its flatness over a lifetime of ordinary use. The machining process creates a slight texture. This helps to capture diamond grit without compromising overall flatness. In use, the diamond particles readily embed into the softer steel to form a durable, fast-cutting abrasive surface. A dedicated plate for each grit size, should you choose to use more than one, cuts the risk of cross-contamination. Each measures 204 x 76 x 9.5mm and weighs 1.1kg.
3.30 3
