Veritas Thickness Calipers
- Accurate measurement of wall thickness
- Designed to reach into deep hollow forms
- Achieve even wall thickness on bowls and hollow forms
- Open callipers, remove and measure tip gap
- Spacing nut adjustable for any thickness
- 140mm throat depth
- Steel with brass fittings
Primarily used by turners, these thickness calipers can be fitted into virtually any shape of vase or bowl. To use, open the caliper by just pulling the legs apart (having the spacing nut between the legs rather than outside them allows this), put in position and then set the spacing nut to the wall thickness. Open calipers, remove and measure tip gap. The spacing nut can be adjusted for any thickness from 0 to 140mm. The throat depth (from nut to tip) is 140mm. These are equally good for dimensional take-offs of almost any oddly shaped object. Steel with brass fittings. Made in France.
EAN Barcode | 722356003893 |
Throat Depth | 140 mm |
- Standard Delivery* - Free
