Veritas Twin Screw Vice
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- The only non-racking, parallel action, full width end vice
- Applies an even clamping force along jaws
- Easy to fit to an existing bench, 300mm capacity
- Telescoping chain cover
- Supplied with two vice screws, nuts, chain, chain cover and wooden handles
This is the only non-racking, parallel action, full width end vice on the market. It applies an even clamping force along the jaws regardless of which of the screws is tightened. Even better, a spring loaded locking pin enables the connecting chain to be disengaged for controlled 'skewing' when slightly tapered workpieces need to be held. Maximum capacity 300mm. The vice is easy to fit to an existing bench, requiring only the addition of an end cap drilled for the vice nuts and fixing bolts plus the vice jaw itself. The telescoping chain cover lets you set the spindles from 11" to 20" apart. Enough chain is included for 16" spacing, adequate for benches up to 32" wide. The kit includes the two vice screws, nuts, chain, chain cover, wooden handles, all the hardware and full fitting and mounting instructions (wooden jaws not included).
EAN Barcode | 722356192108 |
Overall Length | 300 mm |
- Standard Delivery* - Free
