The graceful lines of the Vesper pen help show off your turning prowess. The Vesper is easy to turn with a 10mm single tube. It includes an integrated clip on the cap and a smooth writing Parker ballpoint refill. The integrated stylus tip offers a choice. The stylus tip works on all capacitive touch screen devices such as the iPhone, iPad, iPod Touch and similar touch screen devices. The durable rubber tip protects the device's surface from scratches and smudges. To use the Vesper as a normal pen, just click the end cap to advance the nib through a small hole in the stylus. Requires 10mm drill. When using a mandrel to make these pens, the 103039 Bushing Set will be required.
Graceful pen, easy to turn with a 10mm single tube
Integrated clip on the cap
Smooth writing Parker ballpoint refill
Durable rubber stylus tip for touch screen devices
Click the end cap to advance the nib through the stylus tip
