Viking Arm Precision Lifting Tool
- Universal tool for precise lifting, clamping, and assembly
- Achieve tasks single-handedly that would otherwise be impossible
- Impressive lifting capacity of 150kg
Viking Arm Baseplate & Bars (3 mm)Special Price ÂŁ19.45 ÂŁ16.21 was ÂŁ27.78 ÂŁ23.15 Save ÂŁ8.33 ÂŁ6.94
Viking Arm Cabinet Installation KitSpecial Price ÂŁ50.74 ÂŁ42.28 was ÂŁ72.48 ÂŁ60.40 Save ÂŁ21.74 ÂŁ18.12
Viking Arm Baseplate & Bars (6 mm)Special Price ÂŁ22.39 ÂŁ18.66 was ÂŁ31.98 ÂŁ26.65 Save ÂŁ9.59 ÂŁ7.99
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price ÂŁ79.63 ÂŁ66.36 was ÂŁ89.98 ÂŁ74.98 Save ÂŁ10.35 ÂŁ8.62
The Viking Arm Precision Lifting Tool enables you to single-handedly perform tasks that wouldn’t otherwise be possible. Safely and precisely lift items weighing up to 150kg with the patent-pending lifting technology. The innovative mechanism allows a full release as well as controlled incremental lowering, perfect for applications which require a gentler touch. The Viking Arm can also be used in reverse mode as a clamping tool.
The lift capacity is 150kg and range is 7mm-215mm. The applications for use are virtually unlimited: door and window installation, cabinet and kitchen applications, construction of porches, decks, and flooring, as well as machinery installation and levelling. With a one-handed operation, the Viking Arm can raise the work area and hold in place while you work away, reducing the need for numerous tools - perfect for both trade and DIY.
Made in Norway and extensively tested, the Viking Arm is of sturdy construction and made from high-quality components, comprising stainless steel, hardened carbon steel and aluminium. With a range of innovative accessories available, there are even more options to use the Viking Arm for kitchen installation, precise work and more.
