Viking Arm Tool Case
- Holds 2 x Viking Arms, 2 x Cabinet Installation Kits
- Keep your Viking Arm kit safe
- Hard foam insert, soft foam lid
A perfectly designed tool case to hold all your Viking Arm kit, this case will hold 2 x Viking Arm Precision Lifting Tools and 2 x Cabinet Installation Kits. It has a handy carry handle and comes with a hard cut out quality foam insert to securely hold each item, as well as soft protective foam in the lid. The tool case is W437 mm x H379 mm x D160 mm and weighs 1.9 kg /4.2 lb without tools.
Have everything to hand for a seamless installation, and keep it safely protected with this case!
