WD‑40 Fast‑Acting Degreaser gets to work instantly, cutting through oil, grease, dirt, and grime on contact. Designed to help equipment run smoother and last longer, it rinses away easily and leaves no messy residue behind-just clean, ready‑to‑perform surfaces. The nozzle on the can allows for a wide spray, narrow straw spray and can be used up to 360 degrees in rotation.
Available Sizes 500 ml
EAN Barcode 5032227443921
