Wood Repair Cutting Tool - 50mm
109156
From £54.88 £45.73
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 15th Jul
  • Beech handle with super sharp steel blade
  • Quickly slices excess Knot Filler away
  • Leaves repair flush with surrounding area
  • Greatly reduces clean-up time
  • Perfect for cleaning edge and corner repairs
  • Ergonomic design for greater safety and control
  1. Wood Repair Cutting Tool - 50mm
Total:
£169.22 £141.02
The Wood Repair Cutting Tool is designed to cleanly and rapidly remove excess Knot Filler. The Cutting tool has an ergonomic shaped beech wood handle for easy use and full control when slicing off excess Knot Filler. The heavy blade is completely flat on the underside, ensuring that the filler is sliced flush with the surrounding surface. After use all that is required to finish the repair is a light sanding. The Cutting Tool is excellent for repairing edge and corner repairs.
Size: 90mm long, 50mm wide.
Tip: To keep the blade razor sharp use a fine abrasive paper.​
