Low Price
Special Price £422.96 £352.47 was £469.96 Save £47.00
Out of stock
  • Makes cores from 75mm to 425mm diameter and up to 150mm deep
  • Potentially quadruples output from a single blank
  • Includes three high strength, zinc coated blades with Stellite cutters
Customers Also Bought
Total: £554.03
If you find a particularly interesting bowl blank or have spent good money on one, the Woodcut Bowlsaver MAX3 can effectively quadruple your output. Four bowls from a single blank has to be a good option. Using the Bowlsaver MAX3 coring device, it becomes a relatively simple operation, saving the bulk of your investment from ending up in a heap of shavings. If you use the MAX3 to cut a number of cores from a green timber blank, there is the double bonus of more blanks and a shorter time before you can finish the bowls.
The Woodcut Bowlsaver MAX3 comes with three Stellite tipped, semicircular-shaped blades which are zinc coated to provide a better finish and reduce corrosion. These give you the potential to remove cores from 450mm to 75mm in diameter from the inside of the outer blank. The depth that the blades will go into the wood is adjustable from zero up to 150mm. The small blade’s range is from 75mm to 180mm; the middle blade is 200mm to 300mm and the large blade from 320mm to 450mm (depth 150 mm). The Stellite cutting tips will easily give you up to 500 bowl blanks, depending on the type of wood. Use a diamond file to sharpen the tips.
The Woodcut Bowlsaver MAX3 attaches to your lathe using a tool post and a Morse taper stub that fits into the tailstock of your lathe (MT2). This solid double support results in smooth, accurate results every time.
The Woodcut Bowlsaver MAX3 is suitable for lathes with swing between 400mm and 635mm and a minimum motor power of 1.5kW (2hp) In addition to the Bowlsaver, you will need to choose the correct diameter tool post to suit your lathe from those listed. N.B. A tool post will be needed to be purchased separately.
  • Stellite tips hold an edge 2-3 times longer than M2 HSS
  • 290mm handle that can also be used for 12.7mm diameter tools
  • Two point support for reduced vibration and ease of use
  • Includes MT2 stub taper for the tailstock
This product is on page 348 of the Axminster Tools Catalogue View Page 348
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
