Woodcut Tools Pro-Forme Bent Shaft
- For use with the Woodcut Tools Pro-Forme hollowing system
- Designed for working under the shoulder of the workpiece
- Or with a reverse curve shape that limits the approach of the straight tool
- Supplied as Bent Shaft only
The bent tool is designed for working under the shoulder of the workpiece through a smaller opening or with a reverse curve shape that limits the approach of the straight tool. Supplied as Bent shaft only.
The Woodcut Tools Pro-Forme hollowing system is one of the finest free-hand hollowing tools on the market. It has a hardened M2 high speed steel cutter that is open on the side to prevent clogging, which is common with other end grain/hollowing tools. Its adjustable safety gauge determines the depth of cut and prevents dig-ins. Each cutter is both re-sharpenable using a diamond file and replaceable to ensure a long working life from these tools.
EAN Barcode | 9421905382229 |
- Standard Delivery* - Free
